Pto
   / Pto #1
99johndeere99
Bronze Member
Ovalo TX
JD 4105&ZTR445&RX95
My pto on my 4105 won't disengage still has parcel power
It was fixed under warranty at 20hrs. They said it was some kind of solenoid
Now at hr50 it is starting again. Just wondering if any body else has had this problem
   / Pto #2
Some PTO stub shafts turn a bit when the tractor is running (only a few RPM though). however, if an implement is rigged to the PTO, it won't power the implement. So you might try hooking up a PTO driven implement. If the implement drives, even at low RPM, you definitely have a problem
Since you've only put 30 hours on your 4105 since the original repair, don't hesitate to contact the dealership that did that repair.
   / Pto
Thanks Roy but unfortunately it will start turning the shredder upon start up
It is running ok today.
The other day while picking up some oil the service manager said good thing had it fix under warranty the part was over 800dollars yuk!
   / Pto #4
So, are you going to return it to the dealer?
   / Pto
Yea I am going take it back going get done mowing first and see what happens
2015 FREIGHTLINER CASCADIA (A53843)
2015 FREIGHTLINER...
2012 JOHN DEERE 644K WHEEL LOADER (A52705)
2012 JOHN DEERE...
2020 KOMATSU PC360LC-11 EXCAVATOR (A51246)
2020 KOMATSU...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
2007 Hyundai Sonata GLS Sedan (A51694)
2007 Hyundai...
1999 FORD F550 BOX TRUCK (A54313)
1999 FORD F550 BOX...
