PTO ?
   / PTO ? #1
logan97
Blue Ridge Mnts, Va
Kubota B7800 4/wd
The plastic cover around the PTO came with a chain. What exactly is it's function ? The plastic does spin when the PTO is engaged.
   / PTO ? #2
The chain is supposed to keep the plastic cover from spinning. A spinning plastic cover on a PTO shaft is about the most dangerous thing there is on operating an implement on a tractor.
   / PTO ? #3
I assume you're talking about the PTO drive shaft. The chain is usually provided to hold or hang the loose end from the equipment when it is not attached to the tractor. You would wrap or attach one end around where the top 3 point link hooks to the implement ( brush cutter etc) and the other around the end of the pto shaft to keep it up.
I have seen some youtube clips where the chains are hooked from the top link to the pto covers while the shaft is spinning on the tractor.
   / PTO ? #6
The answers are half right. The plastic tube is a safety shield with cups at both ends to protect you from coming into contact with the rotating steel shaft and the U-joints at both ends of the drive. The chain on the PTO drive end keeps the shield from spinning and the safety cup in place over the U-joint. If the driven end of the shaft were ever to be uncoupled from the PTO drive, the chain would keep that end of the shaft from swinging about wildly.
At the implement end of the shaft, the chain and the cup do the same, keep you from contacting the steel shaft and U-joint. If the shear bolt were to brake, the chain keeps that end from swing around wildly. Remember, we are talking about a shaft that spins at 540, 750 or 1,000 rpm. You do not want to get warped up in the works. :thumbsup:
   / PTO ? #7
Your comment also appears half right. PTO shafts are designed such that when the shear bolt does "break" .... the union just spins with no chance of the shaft "flopping around".
   / PTO ? #8
No, with the shear bolt broken there is nothing to keep the U-joint from spinning and working itself off the implement drive shaft. Maybe it does not happen too often but you don't want to find out the hard way, or do you?:D:D
   / PTO ? #9
The plastic safety shield on the PTO should always be fixed and not spinning. This prevents loose clothing from getting caught on the PTO shaft and the operator being tangled up in the PTO shaft.
   / PTO ? #10
I suspect that's why there are "locks" on both ends of the shaft.
2005 Chevrolet Uplander Van (A51694)
2005 Chevrolet...
2007 Heartland Fifth Wheel RV Trailer, VIN # 5SFGF29267E003752 (A51573)
2007 Heartland...
2008 JLG 450AJ SERIES II MANLIFT (A51246)
2008 JLG 450AJ...
2022 JOHN DEERE 331G LOT NUMBER 99 (A53084)
2022 JOHN DEERE...
2025 New/Unused Wolverine 3 Point Quick Hitch (A51573)
2025 New/Unused...
