PTO yoke won't slide on
   / PTO yoke won't slide on #1
tony83
Granbury, TX
Mahindra 4010
I'm trying to hook up my finish mower yesterday. It was attached to the tractor by the dealer when I bought it. I disconnected it once, and this is the first time I am trying to hook it up (second time attached to tractor ever). The PTO shaft yoke (tractor-end) has this plastic sliding collar instead of the metal push button. The collar retracts three bearing balls within the yoke that allow it to slide over the tractor PTO shaft and lock in place.
The problem is that the balls are not retracting. I can feel spring pressure on the collar when I slide it, but no matter how much prying, pounding or swearing I do, I cannot get the yoke to slide over the shaft past the retaining balls. I have trying greasing it, prying on the balls with a large screwdriver - nothing seems to make a difference. I may replace this yoke with the push-button style, but for right now I would just like to get this stupid thing hooked up. Anyone have experience with these collar-style yokes?
   / PTO yoke won't slide on #2
Are you lining up the splines on the PTO shaft with the grooves in the coupler ??? I have to rotate the PTO shaft until it partially slips into the coupler, before it will engage properly... When they are new, they do fit tight...
Dave
Yes, everything is lined up. I can slide the coupler the first 1+ inch onto the shaft, until the retaining balls hit the end of the shaft. Then no amount of pushing or pounding (with the collar retracted of course) will move it any further onto the shaft.
   / PTO yoke won't slide on #4
Twist your locking collar and look into the female spline. You should be able to push each individual ball down clear of the spline with your finger. Once you have each one free and clearing, it will slide on fine. Ken Sweet
   / PTO yoke won't slide on #5
I had a similar problem with the rotary cutter on my previous tractor. It had the same collar you mentioned. A little WD40 and lots of prying on the balls with a screwdriver solved the issue for me.
   / PTO yoke won't slide on #6
I have the same type of collar on one of my shafts, be sure you completely turn the collar while sliding the shaft forward. It may also help if you raise the deck a bit so the shaft is level from the deck to the tractor. Just be careful the deck doesn't lower and the tractor doesn't roll while you're back there.
I find the push-pin types much easier to attach.
   / PTO yoke won't slide on #7
Good advice. Those balls are the DEVIL!!!
I agree that I would rather have the push-pin type, but I'm going to feel stupid/relieved if it is just operator error. I thought the collar just slid forward towards the tractor - I was unaware that it may also twist. I will give it a try tonight and see what happens.
   / PTO yoke won't slide on #9
Mine slides backwards, away from the tractor.
Terry
   / PTO yoke won't slide on #10
Either Slide back or twist makes no difference, the balls have to go below the female spline. Ken Sweet
2015 KENWORTH T690 TANDEM AXLE SLEEPER (A43003)
2015 KENWORTH T690...
8-Seater Electric Golf Cart (A44572)
8-Seater Electric...
2012 CHEVROLET SILVERADO 2500 (A45046)
2012 CHEVROLET...
2025 8ft Office Shipping Container (A44571)
2025 8ft Office...
Ver-Mac Message Board S/A Towable Trailer (A44571)
Ver-Mac Message...
(1) HD 12ft 6in Panel (A44391)
(1) HD 12ft 6in...
