PTO won't engage
   / PTO won't engage #1
iquester
Stated the tractor today, after mounting new tires, and PTO will not engage. Checked belts - old but not broken, Idler -OK, vacuum actuator -OK. Any ideas?
Removed side panel to observe actuator. All seems to engage except belts don't turn. Is there a clutch on front of engine, I don't see one on the diagram. Is there an electric lock I am missing?
Or could the belts just be old enough to slip that much? Is there an adjustment I am missing? I am stumped. What do I need to look for?
Mike Gardner
   / PTO won't engage #2
you probably did this but check the wiring for the seat safety switch, my JD riding mower came undone one time, worth a look at least.
good luck!
steve
   / PTO won't engage #3
Is the acuator pulling the belts tight?
   / PTO won't engage
Fixed. Actuator was functioning correctly, but PTO brake was jammed. Adjusted it out a little and voila! Thanks for the help from several, and the suggestion from a guy on the IH cadet forum!
Mike Gardner :eek:
Cat 953C Crawler Loader (RIDE AND DRIVE) (A50774)
Cat 953C Crawler...
2015 Ford Transit 350HD Passenger Van (A50323)
2015 Ford Transit...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
Parker 250 bu Gravity Wagon (A50515)
Parker 250 bu...
1270 (A50490)
1270 (A50490)
2013 Ford F-250 4x4 Ext. Cab Pickup Truck (A50323)
2013 Ford F-250...
