quicksandfarmer
Veteran Member
I'm stumped and would appreciate any suggestions anyone has. I recently split my Jinma 354 to replace the oil pump. When I put it back together I replaced both clutch disks and the throw-out bearing. I got it together yesterday, and today I was ready to use it for the first time. However, the PTO shaft wasn't turning. With the engine off, and the PTO engaged, I could easily turn the PTO shaft with my fingers. I figured I must have adjusted the PTO clutch improperly -- it was the first time I'd ever done it -- so I opened the inspection window, and the three adjustment nuts were all too tight, I had mis-measured. I loosened them to give a 1mm gap, but still I could turn the PTO shaft by hand. I loosened them to about a 3mm gap, and still the PTO shaft was turning freely.
At this point I figured that I had squashed the spring, and that either it would pop out on its own or I'm going to have to split the tractor again. So I put the front end loader on and spent about 40 minutes moving some stuff around. When I finished, the PTO shaft was turning, and with the engine off I could no longer turn the shaft. Success! I thought, but it was short-lived. Now I have the opposite problem: no matter where I adjust the clutch, from loosest to tightest, I can't get the PTO to disengage.
The drive clutch seems to work fine.
So I have two questions. The first is about the adjustment process for the PTO clutch. My manual only talks about setting the stack height on a bench to 99.6mm, which I couldn't figure out to do. So I've been going on what I read on the internet, which is to adjust for a gap of 1mm on the adjustment nut. Is this gap measured between the adjusting nut and the main pressure plate, or between the main pressure plate and the PTO pressure plate? Is 1mm the correct gap for this clutch?
Second, where do I go? Any thoughts on additional diagnostics? Should I just split it again?
Thanks.
Thanks.
