PTO Welder
/ PTO Welder #1
RedRocker
Veteran Member
Bowie TX
Kioti CK30 HST, dual remotes, FEL.
I've got an early version of one of these , I want to adapt it to my PTO. My thoughts are building a carryall type frame and mount all the stuff on it. I need to crank the alt. at around 2000 rpm, give or take a few hundred for adjustment. Any ideas on ways to spin it up would be appreciated. I'd rather not have to rev the tractor engine up all that much to get to 2K. Thanks for your help.
/ PTO Welder #2
540 PTO at rated speed?
I'd see if you can find a pully between six and eight times the size off the one on the generator, so you can run the engine somewhere between idle and rated speed.
/ PTO Welder #3
How about a hydraulic motor instead of PTO?
/ PTO Welder #4
Either use the pullys as suggested or consider a small gas motor. You should be able to get a 4hp vert saft lawn mower (new) for about $125. Gear it down about 1.5:1. Then you have a portable welder.
/ PTO Welder #5
I believe that when you used your system on your vehicle, you were running the engine at 2000 RPM. This would put the alternator rotating at least twice that speed. An alternator just does not have much output at that low speed.
As I mentioned in the other post, you could likely find a junked out bush hog or finish mower (preferred) that would give you a gearbox with 3:1 gear ratio. Further step up could come from the pulleys added.
As another gentleman mentions in this post you can also drive it hydraulically via a motor. This is the approach that I am planning on taking with mine.
/ PTO Welder #6
I say go with the pulleys, but they could cost a lot of $$$. /forums/images/graemlins/shocked.gif
/ PTO Welder
I'll dig around and see what kind of stuff I can scrounge up.
/ PTO Welder #8
Find a pto gearbox for a generator designed to run at 3600rpm.. that gives you a 6.6:1 ? right
That will put plenty of rpm on that alternator.. could soup it up even morw with a 2:1 pulley..
Soundguy
/ PTO Welder #9
I've thought about something similar. I want to mount a ~15kw generator on a carryall and use it to run a welder and other electrical stuff, plus backup for the house (we are in the sticks). I have an old datsun 4spd tranny, wonder what kind of ratio choice that would give to match engine load/speed/PTO RPM? hmmmm.... /forums/images/graemlins/ooo.gif
/ PTO Welder #10
I think you'd have to run it "backwards" i.e. PTO to the output side and generator to the input side.
Don't know the rear-end ratio that was made for, but you can likely get 3 or 4:1 out of it. Just put it in 1st and count the rev's out for each one in.....then let us know! /forums/images/graemlins/grin.gif
/ PTO Welder #11
Keep in mind what your pto gen was made for.. if it is a 540 unit.. you will want to be pretty much dead on.. regulation of voltage and frequency on those pto gensets is a very narrow 'acceptable' band.
Soundguy
/ PTO Welder #12
Yeah, the whole 60Hz thing is pretty important as I remember from my days of spec'ing out gensets and battery backups for datacom equipment. I was thinking I could use the tranny to "tune" the tractor to the load w/o having to run it at 1800 RPM all the time.
/ PTO Welder #13
Just keep the engine in a power band. otherwise when the load gets high.. the engine will bog down too much.
Soundguy
Morgan 26ft Box Truck Body (A59228)
Morgan 26ft Box...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A59228)
2015 Chevrolet...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
2026 Quality steel dump truck (A56859)
2026 Quality steel...
2017 Versatille 260 (A60462)
2017 Versatille...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
