Pto weak
   / Pto weak #1
Montes1973
New Holland 3939
I have a new holland 7610 that I believe is a 2000 or 2001 model and it doesn’t have but around 700 hours on it. I had it hooked to a 10ft bush hog and after a while the pot started getting weak and wouldn’t turn.
   / Pto weak #2
maybe disconnect the PTO from the bush hog and see if that is the culprit? If its still weak/not turning, check your hyd fluid level.
If the PTO does work when implement PTO is disabled its something on that attachment.
Divide and conquer..
   / Pto weak #3
I believe the 7610 has hydraulic engagement on the PTO so might have to look into the diagnostic procedure for checking pressure on the PTO circuit.
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2018 Chevrolet Tahoe SUV (A59231)
2018 Chevrolet...
Honda EM3500SX Portable Gasoline Generator (A59228)
Honda EM3500SX...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2016 Volvo Semi (A59814)
2016 Volvo Semi...
2001 Dorsey 48ft Flatbed T/A Trailer (A56857)
2001 Dorsey 48ft...
