PTO water pump delima
   / PTO water pump delima #1
sea2summit
Elite Member
Left coast of, GA
Kubota 1860->25D, MX5800, M4D
So I haul water to most of my critters in an IBC tote that I fill from my pond with a 12V pump. The 12V pump takes forever and it just died.
So, now is my chance to change to something PTO driven. I've looked at a lot of them that chain on for sprayers etc but it looks like about 22gal/min is the max flow which is okay but it doesn't look like they can handle any foreign debris and I can't see anything say they have any capacity for suction or head. I think I need it to be capable of 5-10' of suction, not too worried about head because I'd just be pumping into an IBC tote on the FEL or maybe the 3PT if I get crazy and build a transporter for the IBC/mount for the pump. I plan to have a filter on the suction end but it's probably still gonna see pine needles/leaves/etc moving through from time to time.
Any recommendations? I'd love for it to be 1.5-2" trash/fire pump capabilities but I think that's probably to big for the application. And this would run off an MX5800/540 if that matters.
   / PTO water pump delima #2
We pump out of a pond for a 2 acre water sprinkler system. To get clean water, we layed about a 6' piece of 4" pvc well screen, on the bottom, wrapped with polyester furnace filter material. Has been working good for several years. Have not cleaned it so far. we pump about 50 GPM through it 3 times per week, for about 4 hours.
It came in a 10' joint, but we only had 6' working space.
You might lay it on a small stand to hold it off the bottom, if you thought it might fill in over it.
If you have electricity, or generator available, we use a 1 HP swimming pool pump, to move from pond to holding tanks. It pumps about 50 GPM I think.
   / PTO water pump delima #3
If you make a float to hold the hose and let the suction head hang below the float about a foot you wont get as much crap...
   / PTO water pump delima #4
Agreed with Peter315, keep the intake off the bottom and your job gets easier. Ive run pump irrigation for the garden from a dirty pond and always tied the end of the intake hose to a two empty gallon jugs for flotation.
   / PTO water pump delima #5
If this is something you do often, consider laying a semi-permanent intake in the pond that you can connect the pump to when needed. As others have mentioned, you can rig the intake for filtering debris which will save the pump from that grief.
Pricing on the PTO pump? Have you compared that to other pumps, either gasoline or electric? Some people hate HF, but they have a 2" semi-trash gasoline pump on coupon for $190: Harbor Freight Tools Coupon Database - Free coupons, 25 percent off coupons, toolbox coupons - 2" SEMI-TRASH GASOLINE ENGINE WATER PUMP (212 CC)
Item details are here: 2 in. 212cc Gasoline Engine Semi-Trash Water Pump - 158 GPM
Leave that near the pond connected to the intake and just use a hose from it to fill the tote.
The pond is about 500’ from power so that’s why I’m leaning toward PTO.
Absolutely. Several folks have mentioned semi permanent hookups and that’s actually sounding pretty smart.
PTO pumps are looking similarly priced, and I’ve got a dozen or so small engines I maintain already so I’m trying to avoid that route for now.
   / PTO water pump delima #9
This is what I use. I've used it both for filling my 300 gallon tank from the creek and pumping water for my newly transplanted conifers. The water from the creek is pretty clean and I use a screen on the inlet side. So far I have not damaged the pump from contaminants. The volume this pump puts out is impressive so much so, that I have to run my 2025R at just above idle speed to avoid dispersing too much water. But I have some trees that I can't get my trailer and pump close to so the huge volume of water this pump moves allows me to get the water to the trees.
https://www.agrisupply.com/images/xxl/12242.jpg?v=20201024083443
2006 C&B QUALITY TRAILER GOOSENECK (A45333)
2006 C&B QUALITY...
2022 SPM 2500 QUINTUPLEX FRAC PUMP (A45333)
2022 SPM 2500...
Case 580N EP 4x4 Extendahoe Backhoe Loader (A42742)
Case 580N EP 4x4...
2016 MACK CXU613 TANDEM AXLE DAY CAB (A43004)
2016 MACK CXU613...
2010 IC Corporation PB105 Bus (A42742)
2010 IC...
2018 Dodge Journey SXT Van (A42744)
2018 Dodge Journey...
