pto use
   / pto use #1
NHeuro
europe
NH tce 50 for the previeus see Bio
I had a question about pto.
When i put it on i do it on low rpm 1000-1200 rpm.
But when i drive and i lower my engine rpm fast (i do this when i need to change direction so i can save my clutch)
I this dangerous for my clutch or not?
   / pto use #2
It's always good to engage your pto while the engine is at a lower rpm. I like about 1000 or so. That way it doesn't lug the tractor down excessively.. but also isn't a super shock load. Similarly.. when I go to disengage the pto.. I lower the rpm down quite a bit to save on pto brake wear.
This works good on tractors with mechanical and hyd pto engagements with 'feathering'.. and electronic solenoid engagements with feathering. I have heard of on/off solenoid pto setups that seem to slam engage.. even at low rpm's.. I'm not a fan of those.. etc.
Soundguy
2007 Ford Crown Victoria Sedan (A51694)
2007 Ford Crown...
New Long Forks (A53002)
New Long Forks...
378804 (A51572)
378804 (A51572)
2019 Ram 2500 Pickup Truck, VIN # 3C6UR5DL0KG545677 (A51572)
2019 Ram 2500...
2012 John Deere 7230R (A52748)
2012 John Deere...
