PTO to Deck Belt - GT 2544
   / PTO to Deck Belt - GT 2544 #1
TRD
Georgia
CUB CADET GT 2544
GT 2544 /forums/images/graemlins/confused.gif
I know that this problem has a simple solution.
I need advise on why I have broken two PTO to Deck belts in about 30 minutes. Looks like the belt is rubbing on the bracket that’s directly below the PTO Clutch. The belt is
not twisted when put on. You can (after a few minutes of cutting grass) smell rubber burning, and it doesn’t take long before belt breaks. It’s been carried back too the dealer on two separate occasions.
Was bought new on last of June this year.
Does anyone know of a good Cub Cadet Dealer in Georgia.
   / PTO to Deck Belt - GT 2544 #2
I know it's real easy to accidentally set the flat side of belt down in the idlers below the exhaust. It will slide right in that way. I did that once after a deck removal and the belt jumped off after a few seconds. The first time I re-installed the deck, I missed the fact that I didn't even have the belt over one of those lower idlers! /forums/images/graemlins/tongue.gif /forums/images/graemlins/shocked.gif. The belt immediately jambed and put a huge gash in it. Luckilly, I'm still using the factory belt at 32hrs. With proper rouiting, I can't amagine how yours is jumping /forums/images/graemlins/confused.gif It's a pretty ridgid setup, even with that 90deg bend.
G/luck
Joel
   / PTO to Deck Belt - GT 2544 #3
I imagine it is a routing problem...but if you can't figure it out bring it over and I will have my guy check it out.
FAE UML/SSL 150 VT BL HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
2014 Chevrolet Equinox 2LT SUV (A50324)
2014 Chevrolet...
2013 PETERBILT 386 TANDEM AXLE SLEEPER TRUCK (A52576)
2013 PETERBILT 386...
2006 Hino 268 Truck, VIN # 5PVNJ81T962S11110 (A51572)
2006 Hino 268...
JOHN DEERE 8R 280 (A53084)
JOHN DEERE 8R 280...
2011 Hyundai Sonata Sedan (A50324)
2011 Hyundai...
