PTO stopped working
   / PTO stopped working #1
Princess
TYM723
I have just bought a new TYM 723 and bush hog slasher. Only had it 38 hours and PTO has decided to stop working mid slash...and isnt interested in working at all. Any ideas? No, its not jumped into neutral. Dash switch is on manual, you can push the engage button and light comes on but nothing happens.
   / PTO stopped working #2
Did any wires get pulled off when you were mowing.... :confused3:
   / PTO stopped working #3
Does the PTO shaft on the tractor spin or it's just the mower that doesn't spin?
You can also try to locate the PTO valve solenoid to check if the wires got pulled off as Peter suggested.
Peter not that i can see...but also not exactly sure exactly where to look as it didnt come with a detailed manual. But at first inspection all looks to be where it should
Nope. Disconnected the slasher from the pto and nothing happening tractor end
yep just googling it now.
Just went through it, not a thing mentioned for troubleshooting pto issues.
   / PTO stopped working #9
Try raising your lift arms up and then lowering just a bit, then try the pto again.
Louny....tried it....no jolly
2000 CATERPILLAR 140H MOTOR GRADER (A51406)
2000 CATERPILLAR...
2009 HINO 185 18FT BOX TRUCK (A52577)
2009 HINO 185 18FT...
2011 Ford F-350 Knapheide Service Truck (A51692)
2011 Ford F-350...
2022 Adams CLC-1013 Conveyor - New (A52748)
2022 Adams...
2007 MACK CV713 WINCH TRUCK (A52472)
2007 MACK CV713...
