renegade13
Hello,
I'm a fairly new owner of a Bobcat CT235 so I'm sure this will be a newbie question. I just bought a Fimco 55 gallon 3-point hitch sprayer with a pump that runs off the rear PTO. Most of the stuff I want to spray is supposed to be sprayed at around 40 psi. The rear PTO is supposed to spin at 540 rpm. I have to set the engine rpm at 2,500 rpm for the PTO to spin at 540 rpm. Here's my problem though. At those settings, the lowest pressure I can get on the sprayer is 80 psi. If I drop the engine to 2,000 rpm, the PTO spins slower and the pressure drops to 40 psi. This seems to solve my problem but my manual says to only run the PTO at 540 rpm. Will I damage the pump or anything else by running it at a lower RPM?
Thanks for helping the newbie!!
