PTO sprayer pump/ roundup compatable ?
   / PTO sprayer pump/ roundup compatable ? #1
7864
Thinking about building my own 3 pt sprayer. Upon looking at pto roller pumps in the ag catologs I find some listed as being roundup compatible.I did not know that you needed a special pump for using roundup/glysophate.Whats the deal? is glysophate extra corrosive?How do the pumps differ?Can an old pump be updated to be compatable?
   / PTO sprayer pump/ roundup compatable ? #2
That's a first for me as well. Only thing that would bother me is keeping residue in the sprayer after you sprayed with roundup.
   / PTO sprayer pump/ roundup compatable ? #3
I am also in the process of building a PTO boom/wand sprayer and have seen the Round-Up ready pumps advertised. However knowing how corrosive glysophate is I would still recommend flushing with clear water and anti freeze added to keep the pump healthy.
   / PTO sprayer pump/ roundup compatable ? #4
You have to have Viton seals and components in the pump for it to function reliabily with Roundup (glyphosate). Roundup Ready pumps have Viton internals and seals.
   / PTO sprayer pump/ roundup compatable ? #5
I might add that all you need to flush your sprayer is clear water and a little Nutra-Sol. The only time the salts percipitate is when the glyphosate solution becomes cold (below freezing).
JACTO ARBUS-1000 LOT NUMBER 71 (A53084)
JACTO ARBUS-1000...
2023 UNVERFERTH 432 (A53084)
2023 UNVERFERTH...
JOHN DEERE 4066R LOT NUMBER 23 (A53084)
JOHN DEERE 4066R...
Bobcat 14" Hydraulic Asphalt Plainer (A52384)
Bobcat 14"...
CAT Skid Steer (A50322)
CAT Skid Steer...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
