pto speed
   / pto speed #1
ugabulldog
GA
'04 MF 451 diesel shuttle shift w/ MF 1040 loader
I know pto needs to be driven at 540 rpms. Does it matter how I engage as follows..... I put clutch in and shift pto on (operates based on rpms, not ground speed) then I rev up engine to 540, then let go of clutch to engage pto.....versus letting going of clutch then reving up tp 540 speed.....implement is spinning full speed on first ex, vs slowly getting to speed in second. I mainly use bush hog and auger. Thanks
   / pto speed #2
540 engine rpm is less than idle for most diesel engine. Usually 540 pto rpm is achieved at engine rpm of 2400-2600. Ground speed has nothing to do with pto rpm. PTO rpm is proportional to engine rpm.
jc,
edit: reread you post, your tach most probably shows engine rpm. Do you have a tach for PTO? probably not. it is best to engage pto at low engine speed and then raise the rpm to correspond to pto 540 rpm whether "live, independent or transmission driven pto" to save the components from excessive wearing out.
   / pto speed #3
What does your owner's manual say on the subject? Mine recommends engaging PTO at low engine speed.
Mike
   / pto speed #4
I guess I would ask why do you want to put a big shock load on your pto parts, your clutch and your rotary cutter or auger? Why not set the throttle down, push in clutch, engage PTO lever, and let clutch out slowly, let the implement spin up slowly and when it is spun up, then increase throttle slowly to bring PTO speed up to 540. Don't you think that all the parts will last a lot longer that way? I do. It's your machine and you can do it any way you want, but I would like mine to last a while. Just saying...
James K0UA
   / pto speed #5
I like to engage the PTO at lower engine RPM and then throttle up to PTO RPM. On rotary cutters there is less banging of the blades and on the RFM there is less belt squeal on start up.
   / pto speed #6
I doubt you engine will idle at 540 rpm! The implement does not "need" to be driven at 540. It's designed for 540 rpm maximum speed (some are designed for 1000 rpm). It won't destroy itself it you exceed 540 rpm but the components will wear faster and not give good life. But there is an overspeed limit. For rotating devices, the loads increase with increasing speed so you don't want to overspeed, for example ,your rotary cutter, because you can cause some bad things to happen if you accidently hit a rock or stump, etc.
Always engage your pto from near idle engine speed to lessen the load on the clutch. Then accelerate slowly to the engine rpm that gives you 540 rpm on the pto output shaft. That makes it easy on the driveline.
Augers are different story. You do not drive them at 540 pto rpm unless you are augering water! You run them as slow as you can and still dig the hole. I run mine( rocky clay soil) at around 250 pto rpm (~1000 engine rpm).
   / pto speed #7
i clutch, shift pto in, and then slip a lil leting it out, then throttle up.
I usually engage at just enough rpm so the pto load won't stall the tractor
   / pto speed #8
when i start my pto i do so at about 1200 to 1500.an then i throttle up to the speed i want the pto to run at.
   / pto speed #10
A gradual speed up is going to be easier on everything. Do you take your manual shift transmission and drop the clutch at 2500 rpm? Let me rephrase that. Do you drop the clutch anymore now that you are buying your own rubber? :laughing:
You're less likely to kill the engine if you ease that clutch in with a pto also, even if it is full throttle.
Most tractors I've ever driven that had a tach had a mark for engine rpm required for the 540 (or 1000) pto speed.
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A51692)
2003 Pierce Tilt...
KUBOTA M7-132 (A53084)
2016 Chevrolet Sonic LS Hatchback (A53424)
2016 Chevrolet...
John Deere 853 20ft Corn Head (A53473)
John Deere 853...
2022 DRAGON  130BBL VACUUM TRAILER (A53843)
2022 DRAGON...
