PTO Speed Selector
   / PTO Speed Selector #1
fenneran
Staunton, VA
Kubota L2900
I have a YMG1800D, which has a couple of settings for the PTO speed. From the bottom the order (I think) is: Slow, Neutral, Faster, Fastest. I have always run the brush-hog and PHD at the "Faster" speed, but the other day I made the mistake of putting it in "fastest" setting and it sounded like an airplane taking off. Then it got me to thinking: I wonder if I have been running it at the wrong speed. Do you all have any idea? Thanks.
Frank
   / PTO Speed Selector #2
If you have been running at the "faster" speed which is probably around 900-1000 RPM's, then yes you have. On the Yanmars usually the slowest speed is 540 RPM's which is the recommended speed for bush hogs, aka rotary cutters.
   / PTO Speed Selector #3
<font color="red">"540 RPM's which is the recommended speed for bush hogs, aka rotary cutters." </font>
And most other power implements as well.
So is that more than likely the "slowest" setting (all the way at the bottom of the selector)?
-Frank
   / PTO Speed Selector #6
You should have red mark on the tach, which is the speed to run the tractor, and low PTO. If you do this you will be running it correctly for about an american implement.
Great. Thanks for the information. As an academic question, what is the harm in running it on the faster setting? I imagine it would have to do with design constraints. In other words, it was desinged for 540, so running it at 1,200 (or whatever) may result in it flying apart unexpectedly.
-Frank
   / PTO Speed Selector #8
You have got it, that is the reason. Those gears can only stand so much.
2018 Big Tex Tandem Equipment Trailer (A52384)
2018 Big Tex...
2009 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2009 Ford F-150...
2017 JOHN DEERE 6120M TRACTOR (A51406)
2017 JOHN DEERE...
2018 KENWORTH T370 REAR LOAD GARBAGE TRUCK (A52576)
2018 KENWORTH T370...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A53472)
2014 Doyle Dry...
2002 Fleetwood Expedition 36ft Class A Motorhome (A51694)
2002 Fleetwood...
