PTO SOLENOID WIRES CHEWED.... WHERE DO THEY ROUTE TO MAHINDRA 3510
   / PTO SOLENOID WIRES CHEWED.... WHERE DO THEY ROUTE TO MAHINDRA 3510 #1
swrn65
mahindra 3510
HELLO, as the title states, can't track down where one of the 2 wires connect.... no sign of the other wire. I had a branch take out the plug connector years ,ago, and had them hard wired in without plug... please help, thanks in advance.
   / PTO SOLENOID WIRES CHEWED.... WHERE DO THEY ROUTE TO MAHINDRA 3510 #2
:welcome:
To TBN. You came to the right place to get help.
Do you have the WSM your tractor? In my WSM is a section on the Electrical.
yes, but the diagram is a little much for me to interpret.....
Marilyn bad went to worth I found the wire with nothing more than the ground but for some reason now I have no power going to anything my battery is good the cables leading off the battery or carrying current but no Hazard blinkers nothing
Sorry voice texting...was supposed to say bad went to worse
   / PTO SOLENOID WIRES CHEWED.... WHERE DO THEY ROUTE TO MAHINDRA 3510 #6
Sounds like the power wire is grounding out. Check all your fuses, but fix the power wire first or they will just blow again.
If you could PM with a picture of your wiring schematic, I would be happen to look it over for you.
PENDING SELLER CONFIRMATIONS (A51222)
PENDING SELLER...
2015 FORD F-250XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F-250XL...
Behlen Country 3 pt Leveler (A50514)
Behlen Country 3...
2015 Timpte Hopper Bottom (A50514)
2015 Timpte Hopper...
2017-2023 Ford Super Duty 4x4 Pickup Truck Bed (A49461)
2017-2023 Ford...
2005 Big Tex 10PI 16ft. T/A Utility Trailer (A49461)
2005 Big Tex 10PI...
