>> PTO SHIFTER EXTENSION <<
   / >> PTO SHIFTER EXTENSION << #1
BearKiller
When I got my tractor, the shifter-knob for the PTO was missing in action, with only a threaded stub sticking up.
This was actually a blessing, as I made it ever so much better; whereas, had the knob have been there, I probably wouldn't ever have taken time to improve it.
Being metric, a coupling-nut was not to be had without placing an order and paying the cost of many nuts in shipping; so, I took four regular metric nuts, lined them up on a bolt, and welded them into a stack, making one long nut.
I chased the threads with a tap to clean up any mis-alignment or welder slag.
I drove this stack of nuts into a maybe ten-inch length of maybe 1/2-I.D. pipe that I found in the scrap and welded them in.
I capped the other end by welding on a big chrome lug-nut that had been stripped.
I painted her Massey-Ferguson RED and screwed her onto the PTO shifter stub.
Much better; no longer do I have to lean way over and make a conscious effort to engage/dis-engage the PTO; the shiny new shifter-extension is easily accessable, without getting in a strain to operate it.
I wish I knew pictures; I would show one.:)
   / >> PTO SHIFTER EXTENSION << #2
Sounds like a good idea came together for you, isn't it crazy how the manufactures only provide a nub of a lever to engage the PTO,:(
I was less creative when extending the lever :cool: I sister along side of the lever with another lever I found from a parts tractor welding them together, I then slip a rubber hose over the 2 covering the welds, was for sure much easier to use after 11 year of the other way, and then sold the tractor soon after:rolleyes:
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
Bobcat 753 Skidloader (AS IS) (A50774)
Bobcat 753...
2009 IC...
2015 Club Car Golf Cart (A50324)
2015 Club Car Golf...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
