PTO Shield Repair
   / PTO Shield Repair #1
dourobob
Platinum Member
Just West of Buckhorn, Ontario, Canada
Wheel Horse 522xi
I was using my bush hog last weekend and a chunk of "something" (perhaps a branch but I don't really know) ended up laying against the plastic PTO shaft cover - just enough to wear through the plastic in about 20 minutes and located just where I didn't notice it before it was too late. Has anyone tried to repair the plastic outer cover of a PTO shield? I used the hanyman's friend - duct tape - but that only lasted a couple of minutes. Nothing is jamming and the PTO works fine but I am concerned about the safety aspect. Do I just suck it up and buy a new shield or can something like this be fixed.
Bob
   / PTO Shield Repair #2
The PTO safety shields are fairly inexpensive... $35-40... but why is the shield rotating... to wear a groove into the plastic...? That's what the chains are for... you want the shields stationary around the "inside moving drive shaft"...
If you can, take a picture and post so we can see exactly where the problem is... /w3tcompact/icons/smile.gif
   / PTO Shield Repair #3
Was the shield rotating, or was it pressed against the shaft in that area and wore a hole through?
As pointed out, shields arent that expensive, however if money doesn't permit, a patch with some stiff plastic sheeting looks possible, and is better than nothing. You have any fiberglass on hand? I doubt you will find a glue/solvent that will react properly with the patch and shield material ( if your real lucky, it may be a vinyl product ), but a contact adhesive will probably do the trick.
Remember, the shield shouldn't rotate, jus tthe shaft.
Soundguy
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
UNUSED Polyester Arborist Outdoor Rope (A53117)
UNUSED Polyester...
2018 Hino 155 16FT Cab and Chassis Truck (A51692)
2018 Hino 155 16FT...
MASTER FLOOR HEATER (A53843)
MASTER FLOOR...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2013 CATERPILLAR 320EL EXCAVATOR (A51246)
2013 CATERPILLAR...
