Posthole Digger PTO Shaft
   / PTO Shaft #1
Bluetick1955
SC
Ford 2600
I bough a 3pt post hole digger. Tried to use but the PTO shaft is frozen and won't slide.. I guess been sitting longer than I realized. Any ideas the best way to get apart?
Bluetick1955
   / PTO Shaft #2
Prodigious use of light oil or penetrant to soak into the sliding part then place a board across the U joint and tap it with a hammer to get some movement, then back out. Keep working it back and forth till it loosens up. Pulling it apart might require some force like a come-along with the other end chained to a tree.
   / PTO Shaft #3
do you have a parts washer?
if so, put the shaft in the washer.. or at least part of it. then flip it.
a bucket with diesel in it may help too if no washer. stand it in there and then flip it now and then. even pour thru the center back and forth.
if there is no shield on the shaft take a ballpeen hammer and start tapping down the length to break the rust..
   / PTO Shaft #4
I just had the same problem. I clamped one end in a vise, on the other end I clamped à pair of vise grip pliers then tapped on the pliers with à hammer. It took à while, only moving about 1/4" at à time but it eventually came off. Then I sprayed the shaft with penetrating oil, then greased it and slid the halves back together.
   / PTO Shaft #5
Ditto what George2615 said; tap & beat till the rust breaks. Lotta rust will show on the inner shaft when you get it out. Oil & grease it well before you reinsert to keep it from happening again.
   / PTO Shaft
Thanks. Got to get it off gearbox first. Gonna heat it tonight to get off there
   / PTO Shaft #7
Friend had an old rear cutter. Pto shaft was as solid as a bar of steel. We used a dead fall hammer(no dents) and gobs of WD40. Took half an hour but eventually split it, then steel wool on the male half and lots of grease down the tube.
   / PTO Shaft #8
I got the same problem, Post hole digger was stored outside for about 3 yrs. I have mine soaking in penetrating oil, tomorrow I'll take a hammer to it.
   / PTO Shaft
I put mine between two trees and a chain puller. Pulled so hard snapped drive pin. didn't move. Finally took other end off put in a press. popped when it finally moved the took a log rod and drove it out.Once it moved it wasn't hard to drive out. I buffed the rust off and out put gobs of grease in and slides like a charm. Hung under barn so it doesn't see the rain
   / PTO Shaft #10
I chained mine to a tree today, and pulled with the L3940. Didn't come apart. soaking it some more.
2011 Autocar ACX64 Xpeditor coe t/a refuse (A52384)
2011 Autocar ACX64...
2011 Crown Victoria Sedan (A51694)
2011 Crown...
2022 Ford F-150 Pickup Truck (A51692)
2022 Ford F-150...
2022 Toro Workman 07921 Electric Utility Cart (A51694)
2022 Toro Workman...
2015 KUBOTA M9960 LOT NUMBER 214 (A53084)
2015 KUBOTA M9960...
