PTO SHAFT??
   / PTO SHAFT?? #1
tinman955
Pennsylvania
2011 Bobcat CT450 Cab Hoe
So am I the only one who has trouble hooking up PTO shafts to impliments and tractor? I absolutly have nothing but trouble everytime I hook up anything with a PTO shaft:confused::confused2:
So what is the secret?? Any tips or ideas would be greatly appreciated.
   / PTO SHAFT?? #2
Grease both male and female ends,what I found that helps alot is ,hook-up three point connections and RAISE IMPLEMENT a little,this lets you rotate the pto shaft to line up with splines.:thumbsup:
   / PTO SHAFT??
I greased everything which now gets yr hands all greasy and slippery:D
My tiller I can rotate blades to get things to line up which helps.
But my RFM is a pain in the butt, cant get splines lined up. I fight it, I try to hook up tractor first, then impliment still no luck.:confused2:
   / PTO SHAFT?? #4
Usually one can slide the female onto the male about 1/4 - 1/2" before pressing the button down (I put WD-40 or equivalent on that button). With the button down, slide it on the rest of the way (I don't use grease as it seems to build up with dust and grime over time with grease for me anyway). I spray some WD-40 on the both before assembling. Also, protect the PTO end from being on the ground and catching a lot of water while the attachment is stored, if outside. If there is grease/dirt/grime on the connections, spray with Brake cleaner to clean them up well before trying to slide them together. Get any new paint off if possible. Some tractors come with paint on the male PTO end, and it takes up needed space/tolerance. Clean and dry is the best. No grease on the hands and not slippery to handle.
Some PTO connections have a twist ring that locks/unlocks. Keep these clean as well.
But likely most of us have similar frustrations being in an awkward, hard-to-reach from a difficult position to stand while connecting the PTO. Sometimes they go together real easy, and other times it seems to be a battle.
If I put the PTO on the tractor in neutral (I can on my model JD 4300), the PTO turns very slowly, making alignment easy to do for that first 1/2" or so. Then punch the button and slide on the rest of the way.
   / PTO SHAFT?? #5
I use a spray on white grease (residue is the lubricant and keeps the PTO shaft slick without attracting too much crap). I've never tried raising the implement...just rotate the tractor's shaft a bit (as described in BeenThere's post above). However, I think I will try that (raising the implement a bit) next time I rig a driven implement to the tractor.
   / PTO SHAFT?? #6
I had trouble hooking up 3 point implements when I first got my DK 35.
The problem I had was the PTO shaft on the tractor has a PTO brake. (Couldn't rotate the shaft to line up the splines.)
The CT450 also has a PTO brake and it sounds like your having the same problem I did.
I put a overrunning clutch on the tractors PTO shaft (cost was around $50).
Now I can rotate the PTO shaft to line up the splines and my mowers and tiller go on with ease.
An overrun clutch adds a few inches to the tractors PTO shaft, so you may need to shorten you implements drive shaft.
   / PTO SHAFT?? #7
I've tried a few things and I've had luck changing the height of the implement by just a few inches and trying it again. If the splines don't want to align, I either raise or lower the 3PH a few inches and it almost always goes on. (This after starting with the implement around 1/2 way up). I don't dread having to change implements any more! :)
   / PTO SHAFT??
Lots of good info and ideas I appreciate them and I will try and see what works the best with me.
Like Vince said lining up the splines is the hardest part for me. Cant turn it get lined up very easy.
   / PTO SHAFT??
Do you guys hook tractor first or impliment?
   / PTO SHAFT?? #10
I try and remember to not get closer than 1"-2" from implement pins then climb down and hook PTO to tractor then get back on tractor and back up remaining distance and get back down from tractor and hook draft arms to pins and then top link,so, I stay fit and trim from all the excercise. Having a little working room between tractor and implement is a help. I've a splined slip shaft on my tiller and it's a pain because the sliding part is so short, instead of the tube and shaft like newer triangle type shafts that are full length slide. Oh yeah, I almost forgot, I don't have the over the PTO shaft guard on my tractor. I know it's a safety sheild, but, I just can't work the PTO coupler on with that bloomin' thing in the way. I'm kind old and slow and packing around more weight than I should so I'm not as flexible as in my earlier years and I need things to be easy. bjr
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
41 stump Grab Bucket (A53421)
41 stump Grab...
1987 Ravens 45 ft. T/A Float Trailer (A53117)
1987 Ravens 45 ft...
2025 Future 72in Log Grapple Skid Steer Attachment (A53421)
2025 Future 72in...
1980 TIGER TA KILL TRAILER (A53843)
1980 TIGER TA KILL...
2008 FORD F350 XL SUPER DUTY DUMP TRUCK (A51406)
2008 FORD F350 XL...
