PTO Shaft length Question
   / PTO Shaft length Question #1
KiotiJason
Gembrook Victoria Australia
Kioti DS3510 and 2 x Fordson Power Majors
Hi Gents,
I've replaced my shasher PTO shaft with a heavier duty one. The dealer explaind how to measure and cut it to size however after doing the measurements it fitted straight on.... So know I'm wondering if it's going to be short enough and I'm worried that if its not it could do damage. When it's retracted its about 2" off the PTO spindle on the tractor so I suppose that once it's locked in place it would be about 3-4" of allowable movement. I ran the tractor and did some test cutting and all appears to be working as it should... What's your thoughts and advice? Should I trim a couple of inches off to be sure? Thanks Jason
   / PTO Shaft length Question #2
If it is working as it should when raised and when lowered, it must be good to go on that implement. But I ain't no x-pert/
   / PTO Shaft length Question #3
You might get away with 3 to 4", I'd feel better with 6".....Also, make darn sure the shaft won't be getting any shorter as implement is raised (as in a travel position), or in a side to side sway situation.
Thanks boys, yes the shaft does shorten when raised.
2017 Ford F-150 Pickup Truck (A50323)
2017 Ford F-150...
2013 Jeep Patriot Sport 4WD SUV (A50324)
2013 Jeep Patriot...
Tires (A50322)
Tires (A50322)
2015 Chevrolet Equinox 2LT SUV (A50324)
2015 Chevrolet...
Informational Lot - Shipping (A52748)
Informational Lot...
