PTO shaft fun facts...
   / PTO shaft fun facts... #1
Rara Avis
Veteran Member
VT, ND & OH
John Deere
Did You Know?
The typical PTO shaft can:
Wrap up 424 feet of shoe lace in one minute at 540 rpm, or 785 feet of shoe lace at 1000 rpm. How long is your shoe lace?
Wrap your arm or leg around the PTO shaft nine times in one second at 540 PTO rpm, or nearly 16 times in one second at 1000 PTO rpm. Is your body that flexible?
Produce second degree burns on your skin, even if you are lucky enough to have the PTO strip only the cotton clothing from your body. Nylon and other synthetics will cut into skin and muscle tissue rather than rub across it.
Grind away skin, muscles, tendons, and break bones starting in less than three-fourths of one second when you are caught by an unshielded PTO shaft.
A very strong man can generate about three-fourths of one horsepower. A tractor transmits nearly all of the engine horsepower to the PTO shaft. There is simply no contest; even between a very strong man and a PTO shaft -- the tractor will win.
PTO Entanglements
North Dakota usually has from four to six PTO entanglements per year that result in severe injury or death. There are many more entanglements, however, that result in someone's clothing being partially or completely torn off. This can result in severe skin burns when the clothing tightens up as it is pulled from the body.
Most farmers don't have to try too hard to remember someone who has been caught by an unshielded PTO shaft. Some older people will chuckle about a long-past entanglement. But that chuckle is more of a nervous reaction than true humor. PTO entanglement is not funny!
Any machine that is powered by an unshielded PTO shaft is dangerous. The brand of machinery has nothing to do with its safety, if the PTO is not shielded. You can work with any color of machinery you wish; red, green, blue, yellow, orange -- take your choice -- if the PTO shield is missing, it is dangerous!
How Can You Be Safe When Using PTO Shafts?
First, make sure the shaft is shielded. This includes the driveline shield that covers the implement driveline, and the master shield which covers the universal joint and PTO stub shaft on the tractor.
Maintain the shield so it can work for you. PTO driveline shields are usually mounted on bearings, so they need to be maintained. Always REPLACE the shield when it is damaged or missing.
Next, keep a safe distance from it when in use. Keep others away, too. How far? A distance of twice your height is a good start.
Allow only those who absolutely must be in the area to be there. Keep all children away!
Always pay attention to what is happening. Most PTO victims were caught by surprise.
If something goes wrong -- stop the machinery; take the PTO out of gear, stop the engine and set the brake. Put the keys in your pocket before working on the machinery.
When stopping the machinery for any reason -- end of work, lunch, repairs, or communication -- take the PTO out of gear, stop the engine and set the brake.
More Thoughts About PTO Shafts and Shields
The average replacement PTO shield should cost less than $50 according to North Dakota implement dealers, and will take less than two hours to install.
Can you get an ambulance ride to the hospital for less than $50?
How much health/hospitalization insurance can you buy for $50?
Can you buy an artificial arm or leg for $50 or less?
Can you buy a funeral for less than $50?
Can you look at a picture of your wife or family and say that PTO shields are not worth the cost or effort?
A replacement PTO shield is simply the cheapest insurance you can buy. The time spent to install and maintain a PTO shield is clearly the most valuable and productive time you can spend in your life!
   / PTO shaft fun facts... #2
Paul, you are ABSOLUTELY right. About 15 years ago, my brother and I were replacing some rotten fence posts. The hog wire was still in good condition so we thought we would just pry the wire out of the way and drill in new post holes. Bad Idea! All went well for the first 55 or 60 holes, then the auger chattered in one of the holes, jumped out and snagged the hog wire. In less than a second it had hog wire and my brother's leg wrapped together around the auger. Fortunately his leg was only bruised badly and not broken.
He was actually able to finish the project that day. PTO driven implements, in my opinion, are the most dangerous equipment on the farm.
And whatever you do NEVER leave that tractor seat with a PTO driven implement in operation! It seems redundant to say such a thing, but after logging nearly a thousand hours of PTO operation, a person can become over-confident.
Be safe and God bless!
   / PTO shaft fun facts... #3
Paul,
Im glad you posted this warning , I have given a copy of it to all of our
customers for a few years now.
I read it at least 1 a month to remind me that it can happen to anyone !
Thank You, Ernie
PALLET OF GOLF CART TIRES (A51248)
PALLET OF GOLF...
2021 CATERPILLAR D4 LGP CRAWLER DOZER (A51246)
2021 CATERPILLAR...
UNUSED LONCIN 90 PLATE COMPACTOR (A51248)
UNUSED LONCIN 90...
(APPROX 24) 2" X 3" X 49" THICK TUBING (A51247)
(APPROX 24) 2" X...
2019 KUBOTA KX057-4 EXCAVATOR (A51246)
2019 KUBOTA...
2018 Challenger 1042 Tractor (A53342)
2018 Challenger...
