PTO shaft de-couples in use: Bush Hog
   / PTO shaft de-couples in use: Bush Hog #1
Dave Pee
Bronze Member
Live Oak, Florida
JD 2032R 2015
Hello everyone! My slip-collar PTO coupler has a hard time staying locked. Fairly common JD coupler that has 3 ball bearings in it, to lock on to the tractor PTO.
5 years old. I just put a lot of oil on it to clean it out. Taking it apart is the next step, and maybe a new spring installed.
Anybody else have this problem? Any simple fix that I am missing?
Tnx Dave
   / PTO shaft de-couples in use: Bush Hog #2
Oil it, clean it well, air to blow debris out, maybe even soak it in some kind of degreaser/penetrant. Work it several times, repeat as necessary.
   / PTO shaft de-couples in use: Bush Hog #3
I would disassemble it. There's likely to be debris under the collar that is preventing the spring from fully returning the collar and pushing the balls all the way in.
   / PTO shaft de-couples in use: Bush Hog #5
If you take it apart, please post about it (either here or another thread!) I have one but I don't use it (I swap out the pto shaft with the pull back collar).
   / PTO shaft de-couples in use: Bush Hog #6
You rotate the ring to free the balls to slide the unit together. Once together rotate the ring the other way to lock it. If there's a spring in it the spring may not be adequate the friction of the mechanism - based on my experience. I don't like putting oil where I know dust will be.
   / PTO shaft de-couples in use: Bush Hog #7
1st thing I recommend is sliding telescoping shaft apart & look for chaffing of metal. If male section is rough then smooth with a grinder & apply some never-seize. Reassemble then if pto coupler comes off tractor pto next I would disassemble quick coupler
Thanks guys. I did more lube on the coupler, and oil on the extendable shaft of the mower - it was pretty rusty. Did a few runs thru the yard, and it held together just fine.
PS I have a quick connect assembly on back of tractor, so I can "rapidly" connect different implements. But that makes me have to reach a few more inches into the back of tractor, to get to PTO shaft. A royal pain in the rear! So I installed a cheap extender, about 6 inches long - and now it is much easier to hook up the PTO shafts! No more headaches or busted knuckles!
   / PTO shaft de-couples in use: Bush Hog #9
With a 6" extension, don't forget to double check your shaft lengths. Make sure they are not too long.
SELLICK S80T4E-4PS ROUGH TERRAIN FORKLIFT (A51246)
SELLICK S80T4E-4PS...
2019 Caterpillar 299D2 High Flow Compact Track Loader Skid Steer (A51691)
2019 Caterpillar...
2017 SKY TRAK 6036 TELEHANDLER (A52576)
2017 SKY TRAK 6036...
JOHN DEERE LOT NUMBER 121 (A53084)
JOHN DEERE LOT...
LOOK! (A53342)
LOOK! (A53342)
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
