PTO shaft continues to turn while control is in off position
   / PTO shaft continues to turn while control is in off position #1
Budweiser John
Platinum Member
Dewitt, Michigan
New Holland TC45D
I own a New Holland TC 45D hydrostatic drive tractor and lately the PTO shaft continues to turn after the control lever is in the disengaged position. As such, the attached implement in this case a TPH toto tiller, continues to turn unless lowered to the ground.
I'm concerned about possible safety issues. Is there a quick fix or do I need to involve the dealer? This unit is 12 years old and has about 1600 total hours. It's been a great tractor with no mechanical problems.
   / PTO shaft continues to turn while control is in off position #2
sounds like the PTO clutch/brake needs to be replaced. I would get the service manual and trouble shoot before splitting it. I think the tractor needs to be split to replace it.
   / PTO shaft continues to turn while control is in off position #3
I just had my PTO clutch brake fixed and the guy did it without splitting the tractor in half. He had to remove the floor pan and a couple of covers, pins and snap rings but it is possible to do. He had maybe 8-9 hours in the R&R. If anyone was details of how it was done I will get the process he used and post.
Gravelly Pro-Turn 148 48in Zero Turn Mower (A48082)
Gravelly Pro-Turn...
2021 John Deere 9570R Articulated 4WD Tractor (A50657)
2021 John Deere...
2001 Lexus LS 430 Sedan (A48082)
2001 Lexus LS 430...
2007 JOHN DEERE 310SJ BACKHOE (A50458)
2007 JOHN DEERE...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
John Deere Gator XUV835M 4x4 Utility Cart (A48082)
John Deere Gator...
