3-Point Hitch PTO runaway
   / PTO runaway #1
Alderpops
Kubota M5400
Hi, First Post
I just bought a Kubota L2201 grey tractor with loader, Circa 1982?
It seems tight but the PTO continues to run when the tractor is on, exception it will stop with the clutch pedal depressed,
I,m concerned of potential injuries,
Any ideas on getting PTO to stop turning???
Thanks in advance
Alderpops
   / PTO runaway #2
Sounds like a clutch driven PTO then. Either it's a single stage or dual stage clutch. Either way the clutch needs adjusting.
   / PTO runaway #3
is the pto out of gear?
   / PTO runaway #4
Adding to what farmer 2009 said, have you used the PTO or attached anything to it? If not, when you do, it just may "unstick" the clutch to the PTO - - might be worth trying, sorta, maybe.
   / PTO runaway
:) Thanks guys, I read on another post that the hydraulics may be turning it without force, went out to the barn , started up the tractor and stopped it with a 2x4, i.e. no power or torque from it. So I think it's normal and Ok for now, Thanks
   / PTO runaway #6
That's not normal nor okay. It maybe common. Is it an independent or clutch driven?
If independent you have a leak some where and that leak goes to the motor turning the PTO. So it's an Blown O-ring or a leaky spool. Both should be easy fixes.
   / PTO runaway #7
Have you checked the hydraulic fluid level? Perhaps there is some "drag" occurring in the system. Perhaps even wrong fluid.
   / PTO runaway #8
likely a combo of parasitic drag and worn or no pto brake.
DEMCO SADDLE TANK MOUNTS (A52708)
DEMCO SADDLE TANK...
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
Mini-Excavator Quick Coupler (New/Unused) (A59225)
Mini-Excavator...
2011 GALYEAN 130 BBL VACUUM TRAILER (A58214)
2011 GALYEAN 130...
Golf cart (A56859)
Golf cart (A56859)
2010 KMC 3376 Peanut Combine (A56435)
2010 KMC 3376...
