PTO QUESTION
   / PTO QUESTION #1
bravo2zero
Alabama
I have the JD 5085 with a 8FT pull behind JD bush hog. Question I have is this... I have an Econo Mode or can switch out of Econo mode. Either way it pushes to 540 in either mode. But I notice that in the Econo Mode I don't get as good as a cut. Why is this? Considering either way it's pushing 540 on the PTO?
   / PTO QUESTION #2
Is your ground speed the same in both modes? Suspect you are traveling little faster in Econo Mode.
   / PTO QUESTION #3
The only thing I can think of is the pto rpm is dropping off in Econo Mode in heavier cutting requirements. While Econo Mode may deliver 540 rpm it may not have the power of "normal' mode.
A quick call to your JD dealer may provide the answer.
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A53843)
2011 NORAM POWER...
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
2018 INTERNATIONAL LT625 (A53843)
2018 INTERNATIONAL...
Root Rake (A51695)
Root Rake (A51695)
Tiger Mower Hydraulic Tank Connection (A51691)
Tiger Mower...
UNUSED Grey Waterproof PE Tarpaulin w/Grommets (A53117)
UNUSED Grey...
