PTO pump
   / PTO pump #1
Boss 302
Platinum Member
Va.
Kioti RX6010PS Mahindra 3510 Sold (Gonna miss that ole girl)
I am in the hunt for a good 540 rpm PTO pump that will work well on my Bradco backhoe that needs 9-12 gpm, the reliefs on the hoe are set at 2500 psi. I have a Prince model 2A that pumps 11 gpm but the max psi is advertised at 2250 psi. The backhoe does not perform well with this pump (not enough power). Any of you guys that have the Bradco units and using a pto pump what are you using and how does it perform? I would like something that moves enough fluid to not have to run the tractor at full PTO RPM.
Randall
2021 Toyota Corolla LE (A50324)
2021 Toyota...
Case 1150G Crawler Tractor Dozer (A50322)
Case 1150G Crawler...
2011 Volvo Semi Truck (NOT RUNNING) (A50774)
2011 Volvo Semi...
RYOBI 40V HP BRUSHLESS ELECTRIC PUSH MOWER (A51244)
RYOBI 40V HP...
2020 Ford F-250 Ext. Cab Pickup Truck (A50323)
2020 Ford F-250...
NEW HOLLAND TV6070 TRACTOR (A51243)
NEW HOLLAND TV6070...
