PTO pump shaft question
   / PTO pump shaft question #1
HappyCPE
Hunterdon County, NJ
JD 4320
I am the proud owner of an 8 roller PTO pump. This is my first one, and I got a "kit" with the arm, spring, chain, etc.
Now my question - The pump shaft has a groove, to accept a kind of key. They included a collar to attach to the tractor PTO, which also has a groove to accept a key. This groove has 2 set screws in it, as if to lock in another piece of metal. That other little piece of metal is missing. Essentially I have 2 female components and the only way they could ever mate is to drive the set screws into the pump shaft; that can't be right. Did they forget a part? They forgot to send nuts along with the bolts so it wouldn't surprise me if someone in China has extra parts, like a 3" long x 3/16" square key, left over.
Did I mention I'm new at this?
Please, no jokes about the latest wave of California weddings!
Thanks.
Edit - Apologies about posting this here instead of under Attachments.
   / PTO pump shaft question #2
The shaft on the pump should have a "groove" in it to accept a key. This key will either be a square piece of metal or something that look like a half circle. The other piece should be able to slip over the pump shaft and it too will have a groove in it to accept a key. You would put the key (which should be included) into the groove on the pump shaft and the slide the other part over the saft making sure the grooves line up. this should be a tight fit and may need a little persuasion with a rubber mallet or peice of wood and hammer. Once this is done tighten the set screws and it should be ready to use.
Wedge
OK, thanks. You confirmed that I'm missing the key. Off to the shop again....
   / PTO pump shaft question #4
TAKE THE PUMP!!. There are many size keys. They will be able to fit it properly.
Wedge
1985 Miller Wildcat 350-D Welder (A54811)
1985 Miller...
JOHN DEERE 1700 (A53084)
JOHN DEERE 1700...
JOHN DEERE 648R LOT NUMBER 105 (A53084)
JOHN DEERE 648R...
2017 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A52705)
2017 CATERPILLAR...
FORREST RIVER CHEROKEE CAMPER (A52472)
FORREST RIVER...
2018 CATERPILLAR 815K LANDFILL COMPACTOR (A52705)
2018 CATERPILLAR...
