BigMoB
- Joined
- Aug 19, 2009
- Messages
- 20
- Location
- Central Texas - Coryell County
- Tractor
- 2013 LS R4041H, 1948 Ford 8N
I just picked up a used Long Mfg., Model 1200, backhoe attachment that was originally powered through a PTO driven hydraulic pump rated at 8 gpm @ 2000 rpm. Based on pictures shown in the manual, this pump was attached to the 540 rpm PTO shaft using a gearbox that increased the rpms to drive the pump. Naturally the original gear box and pump are long gone, so I need to find a replacement.
I'm looking at the Prince PTO pumps but I'm a little confused on which pump I should get. Do I get the 7 gpm pump or the 11 gpm pump? Would it damage anything on the BH if I get one of the higher gpm pumps so I could maybe use it with other attachments in the future?
I'm kind of a newbie when it comes to hydraulics so any suggestions would be helpful.
Thanks!!
Thanks!!
