boggen
Elite Member
- Joined
- Feb 22, 2011
- Messages
- 3,789
- Location
- Trivoli, IL
- Tractor
- SSTT (Sideways Snake Tain Tractor) and STB (sideways train box) tractor, dirt harvester
i am wanting to find a cheap PTO pump. that can suck water up from lake to water tank (20 to 25 vertical feet difference) and then turn some valves and have PTO pump and 200 gallon tank, be turned into a spot sprayer. (hand gun with about 50 to 100 feet of hose) ((no need for a booms))
nearest areas for 110V electricity is over 1000 plus feet. i do have generator, but i do not want to carry around sump pump and extension cords. plus haul generator out. just to get tank filled up.
the tractor is an allis chalmers C with 6V setup. being able to use a 12V to 110V cigarette lighter converter, is a no go to run a sump pump. and being able to use a generic 12V pump is also out....
i do NOT want a diaphragm pump. my luck i would have to buy constant diaphragm replacements every year or 2.
i have looked at roller pumps, but i have not found any sort of "specs" that state "self priming" and distance it can pull water up into them.
i have a old 220V 2HP i want to say hayward pool pump. i could pull wet end off possibly, not sure if wet end would allow me to connect to PTO shaft or not though. ((not sure if shaft coming out of motor goes straight into wet end, or if there is a coupler between shaft on motor and wet end))
blah blah details....
wanting to water various plants / trees, and also use as a sprayer, to spray weed killer on fence lines, and some other unwanted plants (multi flower rose bushes) around the farm.
