PTO Problems
   / PTO Problems #1
sgipson
south mississippi
ford 3600 1974
Ford 3600 PTO jumps out of gear when bushhogging. When bushhogging pto shift lever moves forward and pto stops turning.
What to do?????
   / PTO Problems #2
G'day sounds like the detent is not holding the gear engaged does it feel like it locks into place when you engage it?
Jon
   / PTO Problems #3
I'm not familiar with the pto setup on that 3600.. but if a manual engaged system, is there any in/out play on the pto shaft? if so, it will walk a manual engagement out... and eventually chew the collar and shaft end.
the play is usually abearing or snap ring or damaged carrier housing.. etc.
soundguy
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A51039)
NEW 2025 Load...
2018 Toro Sand Pro Bunker Rake with Edger/Broom (A49461)
2018 Toro Sand Pro...
2021 John Deere 333G Two-Speed Hi Flow Compact Track Loader Skid Steer (A50322)
2021 John Deere...
2022 Case IH 8250 4WD Combine (A50657)
2022 Case IH 8250...
2022 Ram 2500 4x4 Crew Cab Reading Service Truck (A48081)
2022 Ram 2500 4x4...
2015 Ford Escape SUV (A48082)
2015 Ford Escape...
