PTO Problem NT 204
   / PTO Problem NT 204 #1
COJON
Idalia, CO
NT-204c
I have just purchased a nortrac 204. I am having trouble keeping the PTO in low gear. When I attach an implement the control handle begins to vibrate and jumps into neutral. The high speed runs just fine. If nothing is attached the low speed operates just fine. Can I access the PTO gears by removing the pto cover. there are two covers, the PTO and one above it. There is one gasket which goes under both covers Any ideas about what might be wrong??
I have just purchased a Nortrac 204. It only has 3 hours on it. I am having trouble with keeping the PTO in low speed. When I connect a implement and put the PTO in low speed the speed control handle begins to vibrate and it jumps into neutral. the high speed operates perfectly. If there is no implement attached the low speed runs fine. Can I access the PTO gears By removing The Pto cover plate?? There are 2 plates on the rear, the plate that holds the PTO in place and one just above it, there is one gasket for both plates. ANY IDEAS??
   / PTO Problem NT 204 #2
Over-applied paint has been known to collect on the bottom of that lever. There's a history of the excess paint actually stopping full travel of the lever into the 540 position. Inspect first, then remove as required. See if that helps before you start pulling other stuff off
//greg//
   / PTO Problem NT 204 #3
The vibration does not sound right to me, You say you can feel it go into that speed ?
You will have to remove the lift box to see .........
Look here under 254LE PTO
Jinma Dealer, Ranch Hand Supply , Compact Jinma Tractors
Let us know
Ronald
Ranch Hand Supply
Thanks will check for excess paint!! If I don't have an implement attached the slow speed seems to run just fine!! Yes I can feel the gears engage but then it starts vibrating and jumps out of gear!! Again if an implement is not attached the PTO will run smoothly at the low speed.
   / PTO Problem NT 204 #5
It vibrates with any PTO driven attachment?
It starts vibrating when you start increasing rpm??, as soon as you engage the pto?, start using the pto??
Ronald
Ranch Hand Supply
Ranch Hand It starts vibrating when I use the slow speed. I can run the pto in high speed (1000 rpm) and the implement will operate fine It does not jump out of gear at high speed. At low speed I have trouble engaging the gear then it will start to turn, then vibration, then it jumps to netural but I can then put it into high speed and it operates just fine. If I don't have the brush hog attached I can operate the low speed Pto and it turns fine.
   / PTO Problem NT 204 #7
COJON, you can contact me through my web site if you choose with a phone number and a time and I will give you a call.
Ronald
Ranch Hand Supply
   / PTO Problem NT 204 #8
With the tractor turned off..check this: is there any in/out play on the pto shaft stub?
Soundguy
Sound guy---- tried the PTO no play up or down, no play in or out, and no play side to side!!
   / PTO Problem NT 204 #10
It's engaging in the 1000 OK and not the 540 ? have you tried holding it in the 540 with your hand or a rubber strap ? we had a few that were miss drilled where the check slice is (the piece with the ball detent ) not allowing it to fully engage
Tommy
Affordable Tractor Sales
2015 Ford Escape SUV (A51694)
2015 Ford Escape...
2014 Ford Escape SUV (A51694)
2014 Ford Escape...
2008 KALMER 4X2 SPOTTER TRUCK (A51247)
2008 KALMER 4X2...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
Heil V-1722 28Yd Front Loader Garbage Truck Body (A51692)
Heil V-1722 28Yd...
2025 Swict 66in Bucket Skid Steer Attachment (A51691)
2025 Swict 66in...
