PTO problem MF 1225/Iseki Tm223
   / PTO problem MF 1225/Iseki Tm223 #1
BOBO1225
I have a compact MF 1225 hydrostatic. This tractor is the same as the ISEKI model TM223. The PTO stopped working and after trouble shooting, I found that the PTO control valve solenoid was bad. I replaced it and the toggle switch that energizes it. Now the PTO works for a short time (5 to 10 minutes) then cuts off. After the tractor sits awhile, the PTO will start up again. Does any one have any ideas on where to go from here? The hydraulic oil level is good.
   / PTO problem MF 1225/Iseki Tm223 #2
hmmm, could there be some kind of thermal switch opening up in the circuit, that may have become weak over time?
CFG Industrial Q.A Hydraulic Breaker (A50121)
CFG Industrial Q.A...
2014 Ford F-150 Pickup Truck, VIN # 1FTFW1CT4EKG42947 (A51572)
2014 Ford F-150...
2016 FORD INTERCEPTOR (A51406)
2016 FORD...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A52748)
NEW HOLLAND 706 30...
Genie GTH-844 (A50120)
2014 International DuraStar 4300 Terex BT3063 30,000LB Crane Truck (A48081)
2014 International...
