PTO Problem Cub 2164 Vanguard
   / PTO Problem Cub 2164 Vanguard #1
FLBill
Florida
Cub Cadet 2164
My tractor's PTO will only engage for a short period of time. After I pull the dash PTO switch the PTO engages. Soon after I depress the forward accelerator the PTO stops working. The time the PTO works varies, but it is never very long. I disabled the reverse and seat PTO cutoff switches. That did not resolve the problem. The tractor only has about 75 hours on it.
What is wrong with my tractor?
Thank you for your help. I and my lawn appreciate it.
   / PTO Problem Cub 2164 Vanguard #2
Might be loose wire in the connector to electric pto , I have White here that blades shut down on with a bump 3 years latter found the loose wire.
   / PTO Problem Cub 2164 Vanguard #3
Pull back the protective sleeve over the PTO harness to check for breaks. Something is dumping the juice to the PTO, it's a matter of tracking it down. At first I would have guessed the seat switch was getting tripped, but if you jumpered it out, that takes that out of the picture.
G/luck
Joel
Krause Dominator 4850-18ft (A53473)
Krause Dominator...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A53473)
GOODYEAR SET OF...
2011 Chevrolet Equinox SUV (A53424)
2011 Chevrolet...
2015 Coleman Dutchmen 274BH Lantern Edition T/A Travel Trailer (A51694)
2015 Coleman...
2006 International 4400 Lift All LOM15-55-1S 60FT Material Handling Bucket Truck (A51692)
2006 International...
2017 E-Z Beever M12R Towable Brush Chipper (A50322)
2017 E-Z Beever...
