PTO powered fence roller
   / PTO powered fence roller #1
Kevin_in_VA
Chesterfield, Va
NH TC30 Hydro
I've been working on re-fencing my property with field fence and found that those big 330 ft rolls were just a tad large to manhandle.
My solution was to weld a 4ft length of 2" pipe to the center of the 2ft diameter disc cut from some scrap 3/8" diamond plate (tread side up), I then drilled a 5/16" hole across the diameter at the other end of the pipe. I then lay the fence roll on it's side and slip the pipe through the center then stand it up and slip the end over the shaft of my post hole digger gearbox. I fastened a stabilizer out of a length of 3x2 heavy walled tubing and placed a 3/4 in bolt through a hole in the end into a hole drilled in the center of the disc, the other end attaches to the drawbar hitch. I can then haul the fenceroll to the site, attach the free end to the first post and unroll it very slowly (PTO barely moving) while driving slowly along the fence line. It eliminates the fore-aft swinging, but still alows a little side to side, which I can live with. When I get a working camera I'll post some pics.
Anyone got any ideas on eliminating the side to side?
Kevin
   / PTO powered fence roller #2
</font><font color="blue" class="small">(
Kevin )</font>
Not exactly sure what you mean here,but TSC offers an option called "Levelwind" That "keeps the roll even and easier to unwind."
No picture in the catalog...geez.....
   / PTO powered fence roller #3
If I can picture what you are describing well enough, to eliminate the side by side could be done much like how a box of aluminum foil works - the "lid" is pushed against the box so you can make a clean cut.
Maybe by putting two supports, one top one bottom, and two round pieces vertically the width of the wire fence, feeding the fence between, might help?
2014 HINO 338 26FT CDL REQUIRED BOX TRUCK (A52576)
2014 HINO 338 26FT...
2019 Energreen EVO 40 Robotic Tracked Flail Mower (A52748)
2019 Energreen EVO...
PLEASE VIEW ALL PICTURES!! (A50775)
PLEASE VIEW ALL...
SHOP MADE MANIFOLD TRAILER (A52472)
SHOP MADE MANIFOLD...
KMC 5610 (A53084)
KMC 5610 (A53084)
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
