PTO out on 1320
   / PTO out on 1320 #1
Low Road Acres
I have lost the PTO on my NH 1320 hst. It will not engage properly when I move the lever into place. It began to jump out while rototilling.
Advice? Please?
   / PTO out on 1320 #2
Advice? Please?
You have damage to the shift collar and/or sliding gears in the PTO driveline. The 3PT hitch cover will have to come off, and possibly the rear axle center section split from the transmission to swap out the failed parts.
   / PTO out on 1320
Rick B.....
Thank-you. This was the clarity I was hoping for and I was told that Rick B would have it for me.
I will look into this shortly. At the same time, am I in imminent danger of causing further damage if I operate the tractor without engaging the rear PTO?
The belly PTO seems fine.
Thanks in advance.
   / PTO out on 1320 #4
Rick B.....
Thanks in advance.
Further damage is not likely unless you have a hydraulic or hydrostatic filter plugged with metal filings.
   / PTO out on 1320
Thank-you. I will be changing that filter in the near future and we will have a look. I appreciate the feedback.
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
2010 Ford Transit Connect Cargo Van (A53117)
2010 Ford Transit...
Selco V5-HD Vertical Hydraulic Baler (A51691)
Selco V5-HD...
2013 W-W TRAILER ENCLOSED TRAILED (A53843)
2013 W-W TRAILER...
KUBOTA SVL97-2 SKID STEER (A52705)
KUBOTA SVL97-2...
