PTO OPS fix for 2544
   / PTO OPS fix for 2544 #1
NibbanaFarm
New England
BCS 739, Cub Cadet 2544
I've been meaning to post this easy fix for what I consider to be an annoyance.
On my 2008 2544 the Operator Presence Switch in the seat will shut off the PTO and kill the engine if the operator leaves the seat. The operator can leave the seat without killing the engine by simply setting the parking brake. However, the PTO is still automatically turned off. This was a major annoyance to me because I constantly have to get on and off the tractor to move sticks and other debris. So I would have to reengage the PTO many times during mowing.
I fixed this "problem" in the following manner. There are three wires coming out of the switch under the seat. I cut the outside yellow wire. That's it. Disconnecting one wire did the trick.
I don't really think this makes any difference safety wise. If the tractor would roll or something happen to the operator, the engine will still shut down.
   / PTO OPS fix for 2544 #2
The only safety issue is that you are getting off the tractor with the blades still spinning. You could fall, trip, pick up something too close to the spinning blades etc. I agree that it's probably unlikely anything would happen but the lawyers have to cover all bases.
Bob B.
IH 686 Tractor (A50514)
IH 686 Tractor...
2014 Chevrolet Spark Hatchback (A50324)
2014 Chevrolet...
2014 International DuraStar 4300 Terex BT3063 30,000LB Crane Truck (A48081)
2014 International...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50324)
2018 Toro Grounds...
CATERPILLAR 308E2 CR EXCAVATOR (A50458)
CATERPILLAR 308E2...
UNUSED FUTURE MINI SKID STEER HOLLOW WOOD GRABBER (A51244)
UNUSED FUTURE MINI...
