PTO operation
   / PTO operation #1
cozonie
Concho, Arizona
Branson 4020
My Branson 4020 has the pto drive running all the time with or without clutch depressed. How do you stop the rotation of the pto drive? If I shut down engine and engage the pto lever the tractor will not start.
   / PTO operation #2
Welcome from Oklahoma. I would contact your Branson dealer and see if there are adjusments or what it may take to fix that. You might also post this in the Branson forum, might be a common problem.
Ken
   / PTO operation #3
Is the PTO spinning due to a draggy clutch? If you were to hook up a load to the PTO shaft will it drive it normally or will it slip? The fact that it will not start with the PTO lever on means the interlock switch is workiing but I dont know how PTO clutch is actuated on your macine. If it is an electrical engagement then I would guess the clutch is just dragging the PTO shaft but it would not be able to carry a load.
If the PTO is on with full clutch engagement then you have a hazardus situation.Be careful. Dont work around the tractor when it is running
JOHN DEERE TS 4X2 GATOR (A51406)
JOHN DEERE TS 4X2...
Valvoline 85/140 Gear Oil (A53117)
Valvoline 85/140...
2021 Triple Crown U6X14T 14ft T/A Flatbed Trailer (A51694)
2021 Triple Crown...
2008 Saturn VUE XE SUV (A53117)
2008 Saturn VUE XE...
2004 FREIGHTLINER FL70 FLATBED W/TANK & DITCH WITCH MIXER (A53843)
2004 FREIGHTLINER...
CAT 941 Crawler Loader (A47477)
CAT 941 Crawler...
