pto operated leaf blower?
   / pto operated leaf blower? #1
accordionman
wright city, mo.
KUBOTA L3000DT, FEL.
has anyone built there own pto operated leaf blower?
i sure need one of those. if anyone has done this, would
you share your plans? thanks.
accordionman
wlbrown
wright city, mo.
   / pto operated leaf blower? #2
I, too, had your same deep desires to blow the leaves away! /forums/images/graemlins/smirk.gif I had the oppoertunity to purchase a PTO leaf blower on eBay for a song. It was a front mount type, but I invested a little money at a local fab shot, and converted it to a rear mount unit. I had 3 pt. hitch pins added, repaced the belt drive to a gear drive assemble (had to reverse the blower blades since the front PTO goes in the opposite direction /forums/images/graemlins/crazy.gif). I added a chain to the top of the unit to act as my Top Link. This allows the unit to kick up, but be picked up when needed. The unit has a single pivoting wheel that now is a "tail dragger" type unit. All works well.
I just finished blowing my 5 acres of leaves, and I have to tell you that blowing leaves is just like pushing snow; when the leaves are just so high, there is no place to blow them. I did get them all around the perimeter of the property, but it took most of the day (10:00 AM until 4:00 AM) But now that I am warm and dry, I guess it didn't take all that long, considering I could have done it by hand. I now have the unit off of the tractor and in storage for the winter. If I had it to do again, I think I would invest in the large vacuum. I'm sure they have their issues; but you know, the grass is always greener! /forums/images/graemlins/grin.gif
Good Luck.
SIR,
do you have any pictures of this unit? appreciate you
posting some if you have them.
accordionman
wlbrown
wright city, mo.
   / pto operated leaf blower? #4
I have about 10 acres of leaves to manage and I was lusting after a blower. However, I decided to try my Landpride "Air Tunnel" finish mower. It is a high-lift side-discharge 72" mower model AT2572.
It did an incredible job of not only blowing the leaves but pulverizing them. The only hard part was planning my paths since the discharge is to the right. I now no longer desire a leaf blower. The finish mower does two jobs.
Mark
   / pto operated leaf blower? #5
Wow...was just thinking about this last month. I still have kids at home so getting a leaf machine isnt pressing (yet). I was thinking along the lines of basing my leaf machine around an old dust collection system fan. Instead of blowing I wanted my machine to injest and pulverize. The output would be collected which could be composed. Ive seen similar truck mounted machines used by landscapers. The fan is run off a small gas engine and the output goes into the truck bed. Anyway, it seems not too complex a project.
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
New Wolverine 3pt Receiver Hitch (A53002)
New Wolverine 3pt...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A51691)
2019 Caterpillar...
2013 MACK ELITE LEU613 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
AMADAS SPC-6 LOT NUMBER 257 (A53084)
AMADAS SPC-6 LOT...
