pto on 4210
   / pto on 4210 #1
stevecres
I have a new 4210 when pto switch is pull on there is instant pto engadgement,is there any way to smooth out this harsh engadgment,something like the old clutch pto engadgment?
   / pto on 4210 #2
My 670 is a gear machine, so this may not apply. I engage the PTO at 1200 RPM or so, rather then at rated PTO RPM. Once engaged, I'll increase the engine speed.
   / pto on 4210 #3
The dealer and manual recommend engaging at a lower RPM like 1200 and then bringing it up to speed. Disengaging at a idle is also recommended, but in an emergency disengaging at any RPM is OK.
   / pto on 4210 #4
On my older machine I simply lower the RPM's down to about 1500 or so and then engage. After that I just crank up the throttle and it is a much smoother transition. I noticed that when I engaged at higher RPM's I had the same problem.
2016 Ford F-450 Crew Cab Knapheide Service Truck (A50323)
2016 Ford F-450...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
Alamo SH88 88" 3pt Flail Mower (A50774)
Alamo SH88 88" 3pt...
New Edco Hand 12" Post Hole Digger (A50774)
New Edco Hand 12"...
2011 Dodge 2500 Big Horn Pickup (RUNS) (TITLE) (A50774)
2011 Dodge 2500...
