PTO - loud noise
   / PTO - loud noise #1
Ideehoan
Bronze Member
Idaho
Kubota B7610, Kubota B1550
I have a Kubota B7610 hydrostatic, used mainly for blowing snow with 3 pt blower. This winter I noted some intermitted noise, high pitch like bearing going bad, figured it was a PTO shaft U joint. Heard mainly when not under load.
I greased and checked PTO shaft u-joints, nothing changed, U joints seem OK. Was not loud so I carried on.
This summer I built a PTO drive air compressor. During testing, the bearing noise progressed quickly. The PTO shaft U-joints seem fine. The noise progressed to loud rattle like something might come apart, worse at idle. Stethoscope seemed to indicate PTO output shaft bearing area. Its quiet when the PTO dirveshaft is disconnected.
I removed the PTO shaft cover. Bearing and idler gear assembly seem fine.
Any ideas on this before I take it to the dealer? Tractor has only 250 hrs, but is off warranty.
   / PTO - loud noise #2
I'm inclined to trust the stethoscope, but I also know how sound can travel through the drivetrain and fool a person. I would need to be there to make a good diagnosis.
Sorry I can't help more.
   / PTO - loud noise
Thanks for the reply.
I'm baffled by this one. Guess I'll let the dealer have a go at it.
I hate taking things to a shop when I don't know what I'm in for.
2013 Chevrolet Malibu Sedan (A50324)
2013 Chevrolet...
2018 WACKER NEUSON CORPORATION DBA WACKER NEUSON LTV6 LIGHT TOWER (A50854)
2018 WACKER NEUSON...
2019 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A50323)
2019 Chevrolet...
PETTIBONE B66 EXTENDO (A51222)
PETTIBONE B66...
2010 Case 660 Trencher (A50322)
2010 Case 660...
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
