daTeacha
Veteran Member
While working with moving rocky dirt in a rough area, my PTO light came on even though neither PTO was engaged. The light wouldn't shut off when I engaged and disengaged the PTOs, and didn't bother anything, so I kept working.
A while later, I shut down the tractor, coincidentally parked in a place that effectively blocked both cars in the garage. When I went to restart it, the PTO light was on and the starter would not engage. Crawling around under the tractor revealed a disconnected wire. Plugging it back in shut the light off and enabled a normal start.
I'm just tossing this out there in case it happens to someone else. The wires and such are pretty well protected by the layout of CNH machines, but they can still get snagged now and then. If things are working and then suddenly aren't, check for a loose wire somewhere.
