pto lever problem
   / pto lever problem #1
hazer36
Bronze Member
First to update about 2000B tractor:got starter for 850 deere bolted right up,gave 139 plus 12 for shipping,no core required,this starter will really twist her. Runs great.
Now for new problem,the pto lever I suppose is to pivot on end of diff lock rod to change pto gears. Mine is froze and wont pivot.moves up and down with diff end moving.I have tried everthing to get it off(tapping,prying,heat,puller)and still no results.
Has anyone every had this problem or has idea to get it off?
Any thoughts welcomed.:eek:
   / pto lever problem
OK guys am I correct that it should pivot at this point. Because I am to the point of cutting it off!
Crosley 10ft Hydraulic T/A Dump Trailer (A50323)
Crosley 10ft...
John Dozer JD650 (A51691)
John Dozer JD650...
Light Tower (A52377)
2017 KENWORTH T880 (A53843)
2017 KENWORTH T880...
2021 Kubota RTV-X1140RL-A (A47384)
2021 Kubota...
2014 MACK GU713 DAYCAB (A53843)
2014 MACK GU713...
