PTO Issues
   / PTO Issues #1
Mdonaghy
Alberta Canada
Mahindra Max 25
Hello all.
I have a 2012 Max 25. The PTO is giving me grief. Lever engaged PTO running, put a small load (as in rototiller tines just touch ground enough to scuff up surface) and the PTO kicks out. Put foot on clutch, wait a couple seconds I can feel PTO re-engage release clutch pedal and tiller turns again...until I load it up then it pops out again. I bought a manual. I've got the top of the transmission off but I see nothing obviously wrong. The only slightly odd thing is the collar that is moved by the PTO shifter isn't all the way into the mating gear on the PTO shaft with the PTO engaged. I tried with a pry bar to pop it out but it aint going anywhere. It's fully locked in place. An there is no sign of any wear at all in the transmission on anything. I probed the oil with a strong magnet and there was no filings or chunks whatsoever. Mahindra told me to check the collar on the "driveshaft" (the input shaft inside the transmission). I looked at it carefully, no cracks(it's some cast or pot metal), you can slid it back and forth on the splines and no sign of wear (as much as I can see of it). So. I'm not sure where to go from here. I suspect it might be the one way clutch on the input shaft but I will have to pull the entire trans axle assembly out and split it to just check it, that's a lot of work for a guess. It took me a couple hours just to open up the transmission. Book time is 6.5 hrs to pull the transaxle(if you know what your doing). Any ideas other than splitting my little tractor in two?
   / PTO Issues #2
My gut is saying it is t fully engaged and a linkage adjustment would do it. That’s a SWAG from someone with mechanical aptitude but no specific knowledge of that machine. But it seems you are thinking the same thing with that collar.
Obviously the tiller is one of the more violent PTO attachments so that’s working against you with regards to something being broken or bent.
2010 Chevrolet Tahoe SUV (A50324)
2010 Chevrolet...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2012 Chevrolet Traverse LTZ SUV (A50324)
2012 Chevrolet...
Barn Wood Picnic Table (A50515)
Barn Wood Picnic...
2013 PETERBILT 367 (A52472)
2013 PETERBILT 367...
2015 Kia Sedona Van (A50324)
2015 Kia Sedona...
