PTO issue on '06 GT1554
   / PTO issue on '06 GT1554 #1
y2kvfr
Berkshires, MA
Mahindra 2538 HST
Greetings!
This is my first post, google pointed me here, you folks have a great wealth of knowledge!
I just bought a used GT1554 with 110 hours on the clock, in decent shape (not perfect mind you) for $1200.
I've already replaced the deck belt as the deck would shake and shudder and PTO would disengage. With the new belt it doesn't shake and shudder, but the disengage issue still exists.
If I place the ignition switch in the 'reverse mode' and press the reverse button, the PTO will engage and stay on. However, if I switch the key back to 'normal' mode, the PTO will disengage. If I have the key in the 'normal' position, sometimes the PTO will engage, sometimes not. If it does engage it will stop anywhere from 5 to 30 seconds later.
Does anyone have the wiring diagram? Is this a common issue? As I've said, in reverse mode the PTO engages and stays on, so I think there is a loose wire in the ignition switch area.
While changing the belt I noticed that the previous owner had the deck welded at the left side hanger, they must have hit something pretty hard and separated the hanger from the deck body, but they did a decent job welding it back in place. My wife is not a 'tractor person', but when I brought it home she jumped in the seat and said, "WOW, this is OUR new tractor?" Crud, I think I just lost the only 'me' time I had!
Thanx in advance,
-travis
Thanx Machinist.
In looking at the diagram, and since it does work properly when in 'reverse mode' I have a feeling I either need to check for loose wires or replace the switch. I'm hoping if I have to replace the switch the warranty will be in effect (but I haven't read the warranty to see if it is transferable).
Thanks again,
-travis
   / PTO issue on '06 GT1554 #4
Oldmachinist:
Thanks alot for that link to the 1554 manual. I just bought a used 1554 although it is in excellent condition with only 14 hrs this manual will be very helpful.
You wouldn't happen to know of a similar link for a service manual for my Kubota 3130???
Thanks again
   / PTO issue on '06 GT1554 #5
I havn't found downloadable Kubota service manuals anywhere. You can buy them in paper form several places but they're a little pricey. MTD has also been cutting off some of the links for service manuals that I have so make sure you download the whole thing and save it.
27ft x 24ft Metal Building (A48837)
27ft x 24ft Metal...
Cat TH407C Telehandler (A50397)
Cat TH407C...
UNUSED LANDHONOR DDSL FUEL TRANSFER PUMP (A50460)
UNUSED LANDHONOR...
2018 John Deere XUV560E 4x4 Gator Utility Cart (A50322)
2018 John Deere...
2011 Chevrolet Impala Sedan (A48082)
2011 Chevrolet...
BUNDLE OF I-BEAM 12" X 14# MISC LENGTHS (10) PCS (A50460)
BUNDLE OF I-BEAM...
