pto hydraulic pump
   / pto hydraulic pump #1
VroomVroom
Platinum Member
Newfoundland
Mahindra 2816 HST, Super M farmall, J5 bombardier, 230 timber jack skidder
has anyone had much experience with these? I saw one in princess auto, made by princess. It slips over the pto shaft, but my question is how do you keep it from spinning the pump body itself? There doesnt seem to be any mounts on it to hold it from spinning with the pto shaft?
   / pto hydraulic pump #2
There should be mounting holes in the side of the pump that a bracket can be bolted to. Then fasten the bracket to the drawbar or other frame part (not the 3pt hitch). I've used them, they work well.
   / pto hydraulic pump #3
My backhoe uses one, there's a lock collar that you use like an air line quick connect, pull back the sleeve and it locks around a depression in the pto shaft. To stop it from turning there's two stop chains that attach to the tractor.
It is a pia having to fasten the chains, I plan on making a plate that you can drop a bolt down thru the tractor to stop it turning as well as hold it in place. The lock collar is a pia as well, not much room around the pto shaft guard so the lock will be removed as well.....Mike
Thanks guys. I blieve there was holes there. I was wondering as normally I would have expected a mount attached to it on purchase. Thanks again.
2009 HINO 185 18FT BOX TRUCK (A51219)
2009 HINO 185 18FT...
2011 BMW X5 Multipurpose Vehicle (MPV), VIN # 5uxzv4c52bl407485 (A50324)
2011 BMW X5...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2020 MACK PINNACLE (A50854)
2020 MACK PINNACLE...
John Deere 10 Shank Chisel Plow (A50515)
John Deere 10...
2015 VOLVO TRUCK VN SERIES (A50854)
2015 VOLVO TRUCK...
