PTO HP
   / PTO HP #1
Charliew
Oklahoma
Agracat
Can anyone tell me what the H.P. is at the PTO of a Agracat 3720. This is supose to be a 35 hp tractor. None of the books I have tell about the PTO H.P.
   / PTO HP #2
I've been told the Chinese rate their tractors hp by the pto?
   / PTO HP #3
If a 30 hp tractor. I 've been told the PTO H.P is 19.8kw(27HP).
   / PTO HP #4
Pretty much every engine manufacture rates the engine at the flywheel. so assuming a 3~5% friction loss then it should be about 32 hp pto. just an ASSUMECTION no dats from that perticular unit.
Mark M /forums/images/graemlins/cool.gif
   / PTO HP #5
Charliew
There are many ways of stating HP. The most common are Gross engine, Net engine and PTO. For comparison PTO is best. Many of the smaller tractors are rated in Gross HP.
Happy Tractoring
Chipperman /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif
   / PTO HP #6
I have a 22 hp Jinma and my friend up the road has a Kioti 20 HP shuttle shift 3 cylinder. I run my tractor @ around 1200 to 1300 rpm's all the time to do all my work. My friend seen my 2 Cylinder tractor with 5 foot bucket scoop up a bucket full of mud @ 1200 RPM's and it didn't bog a bit. He said his would have stalled out without a doubt. You look at a Crafstman 22 HP garden tractor and say HUH??? How can you have two 22 HP tractors that are so far apart in the apparant power even though rated at the same HP? I know gearing has a lot to do with everything but it just doesn't seem possible to have such a different range of actually feeling the difference of supposedly the same Hrse Powers. What are your opinions??
   / PTO HP #7
Horsepower is a measure of work over time. Torque and rpm enter into the equation, which someone smarter than me can post. But in general the engine that makes it power at lower RPM will have more torque, which is the energy that does work. Higher RPM engines can make more HP with less torque (for example, a gas lawn tractor engine)
   / PTO HP #8
Also.. that 22 hp craftsman lawnmower.. might have been rated at 22 hp.. with no driveline or attatchments.. that is.. just the engine setting on a bench.. at max ungoverned rpm.. and it produced 22 hp.. right before the engine detonated..
Soundguy
   / PTO HP #9
22 hp is 22 hp. The Craftsman and the Jinma should be able to do the same work when they are putting out 22 hp if they are honestly rated and geared appropriately. But the Sears has a gas engine that probably isn't rated to operate at 22 hp for any significant length of time, while the diesel engine probably is. My guess is that you probably operate the Sears unit at 12-14 hp continuously and the Jinma at 18-20 hp, and that's why they feel so different, powerwise. Of course the weight difference and rpm difference give them a very different sound and feel, too.
   / PTO HP #10
Thats my point. A craftsman tractor probably weighs 350 to 400 pounds and my Jinma weighs over 3000 w/ loader. Most HP should be used to just get the mass of the tractor moving and the mower spinning for example if using one. With both tractor moving and brush hog going there is no apparant power lag on the Jinma. It would be an effort just to put the brush hog in a little trailer and tow it with the craftsman of comparable Horse Power. Thats what stifles me of these HP ratings................
JOhn
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
TIGER 201 WELDER (A51248)
TIGER 201 WELDER...
THRESHOLD 30" SQUARE OUTDOOR GAS FIRE TABLE (A51248)
THRESHOLD 30"...
1985 Eager Beaver 9D0W Tri-axle Flatbed Equipment Trailer (A50322)
1985 Eager Beaver...
UNUSED CFG INDUSTRIAL M-DRG MINI DIGGER (A51248)
UNUSED CFG...
2019 Ford Explorer SUV (A51694)
2019 Ford Explorer...
