agford4x4 said:
yes, but i was curious about how it works. I can slowly start the pto and then engage it all the way. Is this pto operated with a fluid instead of gears or what? I envision a torque converter type thing with fluid fins. Im curious because another poster noted shearing pins because the independant on his tractor was either ON or OFF and it tended to start abruptly, whereas my independant im able to very slowly start the pto.
Please continue to start your PTO slowly with the engine at low RPM. Before you disengage the PTO, when you have a shredder attached, lower the engine RPM first and then disengage the PTO. Your PTO will last much longer that way. My tractor was purchased early in 2001 and has never had a PTO problem because I follow these rules.
Here is how your PTO works:
The PTO is engaged by a hydraulically operated clutch/brake assembly. It is truly an independent PTO. When you move the lever, fluid is routed to the PTO clutch to engage it. It takes about .8 gpm flow to that circuit. The clutch pads also work as a brake when you release pressure to stop the PTO. Rotation will stop in just a few of seconds even with a shredder.
Many older tractors would allow the shredder to continue to spin freely (like an overrun clutch does). The braking action of the PTO clutch on the DXs is really challenged when a large cutter is attached. By slowing the engine and the speed of the PTO, you will save the PTO clutch. You will also save shear bolts by slowly engaging your PTO. My TC45D (like the DX45) will snap a shearbolt in a heartbeat if I forget and suddenly engage the PTO.
If you have one of the DX35/40/45 tractors, you don't have a regular transmission clutch pedal. You have no other way to feather the engagement of the PTO except the yellow lever on your left fender console. I have used mine so much that I know the exact position where the lever will engage when the tractor is cold and when it warms up. You just learn these things after repeated use.
This last weekend, I was cutting some dry weeds and grass around some small trees. Suddenly, I noticed a different sound and looked back to see the cutter was not moving and the shearpin was just fine. My heart skipped a beat for a second until I realized a tree limb had pushed my PTO lever to OFF. Whew! I lowered the RPMs, engaged the PTO, and continued.
