PTO grinding and popping out
   / PTO grinding and popping out #1
CustomSawing
AGCO ST34A
I have a 2008 AGCO ST34A (same as Massey Ferguson 1533) shuttle shift tractor. Since I bought it used the PTO lever would vibrate out of engagement after a while of tilling or mowing. Seemed the detent or whatever holds it engaged was worn out. Too keep it engaged I used a piece of strapping to hold the lever and had no issues.
I was tilling yesterday and hit a rock. It snubbed the tractor out. PTO shaft does have a slip clutch but it must have been adjusted too tight. I restarted the tractor and engaged the pto. Pto spins and will turn tiller but a grinding/vibration will not keep the pto lever engaged. Even if I hold the lever with my hand it wants to push out of engagement. I removed the tiller and have the same grinding and pushing out of engagement with no attachment connected.
With tractor off and pto engaged I cannot turn pto shaft by hand. There doesn’t seem to be any play in and out or side to side with the pto shaft. If I disengage pto lever I can spin the pto shaft freely like normal.
Any ideas?
   / PTO grinding and popping out #2
Probably a damage to a bearing on the tractor, you should investigate it before using the tractor anymore.
2021 HAMM HD+9I VO DOUBLE DRUM ROLLER (A51246)
2021 HAMM HD+9I VO...
2025 LandHonor LHR-LB9510 Leaf Blower (A52378)
2025 LandHonor...
2019 CATERPILLAR 262D3 SKID STEER (A52705)
2019 CATERPILLAR...
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A52705)
2018 CATERPILLAR...
UNUSED DIGGIT 6' HIGH FENCING - 1 ROLL (A54757)
UNUSED DIGGIT 6'...
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATE (A54757)
UNUSED LANDHONOR...
