PTO generator for T273
   / PTO generator for T273 #1
jimmy123
West Nyack NY
TYM 273
Has anyone tried to run a PTO generator on there TYM273 ? I am interested in buying one but the PTO HP is 20.7hp and I cant seem to find one that will run on that HP. Maybe I am not looking in the right place.
   / PTO generator for T273 #2
I have an IMD 10 kw, that would be about max kw you could produce with that 20 hp, since the rule is 2 hp per kw. But you could and maybe should get a 12 or 15 kw. you will still only make around 10 kw, but the extra spinning mass helps to stabilize the voltage and frequency regulation and also helps keep the genny running a little cooler.
There are alot of generator threads, and alot of interest here in generators.
Here's a link to imd
http://www.imdllc.com/index-5.html
JB
2014 Dynapac CC4200 Tandem Vibratory Roller (A52748)
2014 Dynapac...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2004 Kia Optima Sedan (A51694)
2004 Kia Optima...
2016 CATERPILLAR 305E2 CR EXCAVATOR (A51246)
2016 CATERPILLAR...
6" & 8" I BEAMS UP TO 16' LONG (A51247)
6" & 8" I BEAMS UP...
2022 COSEN INTERNATIONAL INC V-1822 BAND SAW (A51248)
2022 COSEN...
